13 Metallic Tahoe Auto Rear Leveling Shocks
Dustin Jackson
@iamdub What is FYP? And for some reason I thought he only had the auto level in the rear. If he has auto level in the front and hasn't adjusted the ride height sensors he has even more ride quality to gain
FYP = "Fixed Your Post". I changed the last part of your post for accuracy. You said he'd have to adjust the sensors to compensate for the shock extension brackets. The sensors measure the position of the arm to determine ride height, which was altered by the lift. So he'd have to adjust the sensors to compensate for the lift.
The ride height sensors tell the controller how to adjust for both the AutoRide and the Auto Level Control systems. Yes, for ALC, getting the rear sensors set is most important. But, since it is lifted front and rear, the controller would be trying to adjust the front struts and maybe (likely) the rear shock valving, and erroneously, at that. So, not as critical. But, if you're fixing one pair, why not fix the other to keep the system as happy all around? It'd at least keep the front from bottoming out if he ever unloaded the front end.
ACPTECHS
