1998 Suburban Driver Door Lock Issue
Jcampbell
My '98 Suburban started having door lock issues recently. The key locks and unlocks the door from the outside. The fob unlocks it. But the fob will not lock it even though I can hear the actuator working. Inside, if I press the Lock button on the door panel about 8 times, it will lock. I figured the actuator was bad (25 years old truck....) but it still doesn't work with a brand new actuator. Could it be the actual latch assembly inside the door? Help!!
Big Mama
Virginia
Welcome to the forum from Virginia. Is the actual lock knob/button sticking or out of alignment?Sometimes they get twisted and won’t go in the recess straight.
YukonGTmaster
You need a good spray lubricant. Spray it in your lock cylinder, and spray it on any linkage or moving parts you can access. Work your key back and forth and cycle the locking mechanism. The lock at my barn door was all frozen up, and I was able to free it up like this.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Welcome to the forum from Oregon.
Yes, what @Eman85 said about age creating problems and what @YukonGTmaster said is spot on and the mechanisms need check for binding and lube it all. The key turning applies more pressure than the actuator. I would also bet that even with the key turning, it is not as smooth as new. Every chance I have a door panel off, for anything, I spray some lube on anything that moves.
Eman85
Lube is good, but many lubes attract dirt. I've fixed a lot of auto lock problems by removing the latch assembly and washing it in the parts washer then lubing it. Unfortunately the doors on these vehicles was engineered by a person that hated mechanics and thought no one would ever need to work in there.
Welcome to the Forum from NH.
Pics of the truck, please.
willb
