2 inch lift 2021 z72 with magnaride
texhost
Can y’all please send me a part number for a lift kit that will work with magnaride and a z71. As it has been discussed before, the rough country website says that their 2 inch kit will not fit z71 and magnaride. Should I just invite that notice? Or is there a different kit that will work. I have looked high and low for a definitive answer regarding this in this forum. Thanks for your help!
Punteh
There's this one that just needs another part for magneride:
Ready lift also has a 3" kit that's supposed to work with magneride:
ProfeZZor X
High Country
I have the SST 3" kit. I've had it installed since June last year, and I really like the ride height. It gives a commanding appearance on the road, and also gives you that height advantage when there's an obstacle or accident causing traffic ahead. But, if you're going to add a lift, you might as well put 35's on it too.
JR09country
Is magnaride a stand alone option on the z71? I was under the impression you could only get magnaride on the z71 if you have the air suspension. I know it's different for other trim levels like the premier, high country and Denali.
Joerob25
