2005 Chevy surburban fans don’t work
Chevywalt66
Hi i have a 2005 Chevy surburban I found that my fans are not coming on. So I unplugged the temp sensor and they run high speed. So I replaced the temp sensor and they still don’t come on. What do I do.
Fless
Super Moderator
Elev 5,280
Welcome to TYF!
Tell us a bit more about your Suburban -- year, etc. so we can put this thread in the right section.
Maybe put it in your signature so it's always there for us to see.
after you replaced the temp sensor, do you get the correct temp on the cluster?, did you get the engine up to running temp? does it overheat while idling? turned on the ac/defrost?
results?
previous history? has the temp been reading normal? any work done to it?
C
Chevywalt66
results?
I do get correct temp at cluster. I turned the ax and defrost on and still does not come on. The only time it will come on is when I disconnect the temp sensor both fans come on at high speed. No previous work done to truck.
C
Chevywalt66
Also my AC system is not operating and it is not filled with refriedgerant. It has a leak and I’m waiting on parts to replace compressor and drier.
C
Chevywalt66
results?
It never overheats. It runs a little high at idle in town but that’s it.
bl74
