2015+ Tahoe/Yukon/Escalade Tech Info
RB Smith
I bought a new filter, but cant get the glove box out. I removed the 2 screws on the top and then the 2 under the box and also removed the cable, which is on the right side. it still wont budge. Any ideas? The manual makes it look easy, but has a picture of screws inside the actual glovebox. I don't have screen in the compartment. Thanks.
Greetings, you will need to press in both sides of the glove box in order to release it from the interference fit on both sides of the box. Once you press both side in enough the glove box will rotate fully down and you will then have access to the cabin filter cover.
Jnice28
