2017 Chevrolet Tahoe TSP 5.3L L83 V2 Stage 1 Camshaft
Ibustbravo
Centennial, Co
IM also looking to add some extra juice to motor as well this particular cam will add an additional 58hp and 24ft/lbs of torque at the crank
Going on a cam timing tangent here.. I'm staying away from the aftermarket cams for now. I went the opposite direction and used a smaller duration cam for this engine.
Yesterday I made three changes, power enrichment pedal enable, PE torque request and adjusted the cam timing. Check out the pictures of the cam timing table. It revs out now.. where as before the engine would run out of steam in the higher RPMs.
Changed 12419 PE pedal enable
Changed 12418 PE torque
Changed 33102 and 33103 reduced by 50%
TU1881
