2021 Leveling/Larger tires
LekGMC
I’ll be doing the same tire size, perhaps 65 series, and stock GM 18’s…..a 1/4 spacer is all that I think will be needed to clear arms. Maybe some minor trimming, but with a 3.5” lift I doubt it. A level, I’m sure you will be trimming. Maybe more than you want.
I’m fine trimming. I have a raptor and trimmed a lot to fit 37’s. I’ve had plenty of trucks in the past that I’ve had to trim up. Part of me going big with the tires…is that I will definitely be going bigger with the lift later. Pretty sure it was you who I was talking about the magnetic ride lifts with. Even on ready lift’s site, in the comments, they say a lift for magnetic ride lift is coming in just a couple weeks. Figure I go big on the tires, then I won’t have to get bigger tires even if I go up to a 3-3.5” lift
Farbs23
Looks great!
That what I’m running.
[/QUOTE]
So did you have to do any trimming on that or is it all stock I have my 22 Tahoe Z71 being built next week was looking for 22” Black Honey Comb wheel but hearing all different sizes for tires 33x12.5R22 then i just seen yours 285/55/22 just wasn’t sure what’s my best bet
Morales1995
Here is some before and after. 2022 Tahoe Z71 with Rough Country Level Lift, Black Rhino Wheels 20x9 0 offset and 295/60/20 Nitto Recon Grapplers (33.94x11.7). I also replace the ugly grill and fender emblems with black ones. Slight rub at full lock on both sides near the rear of the fender well, fixed with minor cutting. Slight rub on driver side at the front of fender well, fixed with minor cutting behind the felt. Rubbing only occurred at full lock out. Hope this helps those trying to plan a build!!
View attachment 355192View attachment 355193View attachment 355191
How far do the tires stick out on this bad ass hoe??
Msmart123
that looks really good. Are the spacers needed to keep them from rubbing?
Did you have any issues with installing the rough country 2 inch lift kit on Z71 Tahoe. It says on Rough country website it won’t work with Z71
dothatagain
How did the ride change? Planning this on our Z71, but the wife dislikes changes to ride quality. She tolerates it, but I'd like the preempt with your experience. Here is our 22 factory height with 33s.
dothatagain
Is this the 2" RC lift?
DH24YUKON
