2022 Tahoe aftermarket airbags for towing - do they exist?
olyelr
Elk Rapids, MI
Those are probably just aftermarket replacements for the full air suspension equipped vehicles. Not sure though, didnt really read about them.
olyelr
Elk Rapids, MI
It says they are setup to add your own air system…so most likely not a replacement unit for the oem then.
dbphillips
The air bag appears to replace the coil spring. I'd definitely like to see a review before dropping that much money, but if the big boys are going to ignore the highest volume full size SUV, may have to roll the dice...
dbphillips
Can you not lift the truck by adjusting the spring stops? Might have to use stiffer springs, depending on what they ship with, but theoretically would move the compression up two inches from current.
cervantesjesus174
