Deuce16GMCs
- Joined
- Aug 11, 2016
- Posts
- 202
- Reaction score
- 111
I've searched and searched and there only seems to be a one post here or there.
Hopefully, we can consolidate the it all to one spot.
For those of you that have changed the bulbs in your 2021-2023 Tahoe's and Suburbans, do you have recommendations for bulbs?
1) From what I've gathered, the turn signal has no issues with resistance.
What's the best bulb you all have found?
2) From what I understand, the Reverse lights can use a LED along with a resistor.
What bulb is the brightest?
What type of resistor did you all use?
Any luck finding a bulb that works without a resistor?
3) What's the deal with the brake light? Anyone replace the bulb? Does it also need a resistor?
Hopefully we can keep all of it one place and it helps us all out.
