David Kriss
- Joined
- Nov 20, 2017
- Posts
- 36
- Reaction score
- 31
I have a 2001 Yukon XL SLT. The ABS light comes on intermittently. I had the dealer look at it and they read the OBD II code. It indicated a bad ABS module. I misplaced the paperwork that had the code so I don't know which code was given. The dealer said that the module is no longer available from GM. If they could find one, the cost would be over $1200. If I get one from an auto parts store. I have to figure out which of the several they have listed is correct and I have to get it flashed by a dealer. I found a couple places online that will rebuild the module. The OBD II code the dealer read is one that both placed say will be fixed by a rebuild and I won't have to have the module flashed by a dealer. The cost is less than $150 at both places. Has anyone used a rebuild place and are they any good? The places I found are circuitboardmedics.com and www.upfix.com. Are these places any good or is there a better place that I should use?
