Adjustable Pedals-manual jump?
Robt342003
Recently the adjustable pedal feature on my 2016 Yukon Denali has stopped working. From the research I've done it could be a bad switch, switch, motor or relay. I hear the relay kicking on when the switch is activated. The fuse is good too. If I remove the plug that goes into the motor can I manually jump the motor? I rarely use the pedals and would really just like to move them into the most down position and leave it be. Which pin is hot to activate the motor?
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
wamba the fool
I have the same issue on two of my trucks. Is there a possible manual adjustment?
Jnice28
