Blocking off rear heater
B
blondie70
When I was ordering some connectors to bypass the tee....a split ring plastic tool was listed among the connectors. I ordered it....hope it is the rite one and works !!! Think it was the Gruven site.
89Suburban
Bull in the china shop
SE PA
Be prepared for coolant in the face.
Invest in one of these to help keep that to a minimum. You can disconnect the tee at the firewall and run one of the tubes down as far as it will go and suck it dry. I use it for all my fluid extractions. I was able to replace a radiator without a drain pan. Just removed coolant as I took things apart from top to bottom.
Also good for draining the transmission pan to do a filter change without a bath.
Bevy
