Body Control Module "BCM"
Partsguy19
Hi All,
Recently my ABS and brake light starting coming on on my 2001 Tahoe. Had it checked out and was told my BCM was causing the code. I see they make replacements (Delco and A1 Cardone etc.). Are these simply "plug and play"? Don't they have to be programmed to your vehicle? Guess I'm a little confused.
fiatdale
Houstons Best
Houston
Yes - it will need to be programmed at the dealer. The replacements are usually "blanks" with no options on them. They need to be programmed to tell what features / codes your vehicle has.
retiredsparky
The BCM does not often fail. I would follow the wiring and look for corroded/loose connections before replacing the module. Check the connections on the module itself as well. check all known grounds.
How old is your battery?
mcclish2012
