Cadillac Ride on a 3/4 Ton Truck?
S33k3r
S33k3r
Dallas, Texas
Best thing you can hope to do is throw some half ton springs in the back and use airbags to get back the hauling capacity. Because a 3/4 ton in never going to ride smoothly as you are seeming to want it too.
I was not clear: The stretch goal is Denali/Cadillac/Lincoln smoothness. Getting it any smoother than original, stock is in the correct direction. And thanks, everyone, for the good advice.
Mudsport96
40.923,-89.488. Illinois
Surely a set of Firestone bags and compressor setup would be cheaper than the H1 set up?
Maybe, i had a H1 compressor and valve setup in my old blazer for years. Got it at a swap meet for 100 bucks. Used it to air up tires after airing down for sandy terrain.
Mudsport96
I THINK there is a 2006 3/4 ton Denali option for 2006. I looked on rockauto and found 3 sets of leaf springs. A 4/1 set and two 5/1 sets. I would venture the 4 and 1 is the softer Denali set as they are listed as 2025lbs. And the two 5/1 sets are 2235 and 2600 respectively. Probably about as soft as you can get and retain your capacity without added help
SWoolf777
