Fuel pump only replacement 07 suburban
soundsgoodtome
I have an 2007 suburban 8th vin J non flex fuel.
I’ve taken the fuel pump out and I am looking for a replacement for the pump Only and not the entire module/housing.
After extensive Internet searches I have been unable to find the pump only.
Does anyone have a number or model for this unit?
Fless
Super Moderator
Elev 5,280
I responded to your other post, but here it is again: Have you looked at Rock Auto? They sometimes have the pumps alone.
S
soundsgoodtome
Thanks for the suggestion. I have looked on rock auto and they have a no-name brand pump. I’m actually looking for a GM/Bosch/…
S
soundsgoodtome
I found the one on rock auto. No name brand something something. I’m actually looking for a GM,Bosch,…
I’m thinking if somebody has made one that’s a cheap piece of junk I’ll bet you somebody else has made one or knows the model number that will cross reference to one.
if you really want to shortcut by getting just a pump then I would take yours a part and look for the numbers on the pump. gm does not sell "just a pump"
delphi probably doesn't either, you might get lucky with bosch, maybe
you could try Herko, they sell things as there own brand but are in fact oem
S
soundsgoodtome
These are the only numbers and this is on the top cap Of the fuel module.
I also have some pictures of the pump itself. Sadly no identification markings on the pump whatsoever. I’m assuming it was made by Bosch but I cannot find any way to source it.
S
soundsgoodtome
Pump
CWinstel79
