Fosscore
- Joined
- Apr 16, 2014
- Posts
- 10,473
- Reaction score
- 18,076
Looks great!!!Thanks. Just swapped out the headlights with the Depot projectors and new lower blinker/DRL housings as well. The last set broke when the radiator blew out. Waiting till I go to work tonight to see the difference in the lighting. Also added the LED license plate lights. I didn’t swap the oem brackets onto the depot lights yet tho. Gonna see how well they ride on the highway. If they move at all I’ll pull them off and swap out the brackets. Will update night shots later.
Also got the brand new bumper pad installed and aligned. Slowly but surely it’s coming around.
Ping pong ball trick works with Depo brackets which are a bit flimsy. I went into more detail with pictures in my NBS thread. I did try to swap the OEM and Depo brackets, but did not have good success and ended up with 2 pp balls in each brackets that funnily enough worked well. There were other threads before me about this hack/trick/simple fix.
Your mileage may vary, but many that front end sure is looking sweet!! A bit of NBS envy here. Keep up the good work!
