Heat/AC Actuator issues
christoddotis
I have a 2002 Tahoe with an issue with Heat/AC Actuator. The actuator for the Heat/AC quit working about a month ago. I tested the motor and it was bad, so I replaced it with an AC Delco unit and it still doesn't work. I tried a Dorman Unit and its still the same. I also replaced the Heat/AC controls and still nothing. Does anyone have have suggestions where I should go next? I would appreciate any help!
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
@swathdiver may be able to assist you.
Which actuator did you replace Chris?
BlazinMilk
