Michigan
- Joined
- Sep 6, 2016
- Posts
- 258
- Reaction score
- 130
2004 Tahoe z71 4x4
175k miles
Owned it 1.5 years
Got it with 149,500 miles
Has had a minor leak since I got it (was lied to about no leaks)
I used Mobil 1 5w-30 full synthetic high mileage and changed oil religiously every 5k miles along with Mobil 1 m107 oil filter
Always kept an eye on oil level and topped off if needed. Maybe a quart or slightly more every oil change
Engine ran very strong the whole time of owning
Without any signs it has developed a clunking sound on startup. This all happened in the past two days. Actually I had the oil changed yesterday and coincidentally it got way louder after the oil change. Before the oil change I barely noticed anything and I wasn’t even suspecting anything really.
On cold start it is very loud. Clinking/rattling noise. I was told by 2 shops it’s the bottom of the engine. Both shops were confident that that’s what it is. Then there is a junkyard across from my work and it took it to him for a third opinion and he says he’s certain it’s the flywheel that’s cracked. I called one of the shops back and told the guy I’m not going against what he’s saying but I asked him the possibility of it being the flywheel. He said that’s the first thing they checked, he said they removed the cover and all the bolts or screws where there? Not sure exactly.
I tried posting a video through YouTube but for some reason it won’t download. It just keeps saying processing. I tried posting a video directly on here and it says file too large. I’ll try to figure out how to get a video clip soon. I know not much you guys can go by without a video and still hard to diagnose by video as it is but would like to got some opinions
Also is there anything else I should have replaced if I have them do the swap. Both shops are suggesting to get a used engine to throw one in.
First shop say he located one with 113k miles from a guy that they do business with regularly. He want to charge 2,500. Not sure about warranty with him but he said he’ll go through the whole engine before installing and replace any manifold bolts of broken, plugs and what not
second shop said between 2,000 and 2,500 not warranty and can’t promise leaks or anything.
175k miles
Owned it 1.5 years
