Burban22
- Joined
- Jun 25, 2023
- Posts
- 132
- Reaction score
- 149
I’ve checked the intake air temp sensor and it’s correct according to my scanner. Example 50 degrees out and iat is reading 76 idling.
Negative fuel trims means you have a restriction, negative means deducting fuel ... a clogged up fender intake with leaves?Disconnected battery for an hour and now get these values.
Idle
2k rpm
3k rpm
These are all done at operating temp and in park. I’ve noticed engine vibration and feels rough at 2k rpm but smooth at all other rpm, idle. Maybe it’s the clutch fan making vibration at 2k? 1.8k rpm is smooth.
I ordered a fuel pressure gauge and found that my innova 5610 supposedly does injector balance test. Says to connect fuel pressure gauge and it tests one injector per key cycle.
I actually tested this by putting a piece of tape over the screen for the MAF sensor the fuel trims went negative -12-15 from positive 15-18.
looks like we found the issue did you connect that hose that connects to the OEM intake ?Fender and intake are not restricted.
It’s a afe cold air momentum intake. Filter is clean. Should be less restriction than stock air box. Maf is clean.
I just did knock sensors and intake gaskets. Never had an intake leak but rear knock sensor was full of water so it failed and started throwing a code for low voltage.
I’ll have to check fuel trims again once it’s up to operating temp.
