Loosing lift after alignment?
88lance
Got the '02 Z71 almost leveled with some lift keys.
Sitting 1/4" lower in the front, which isn't bad.
You can definitely tell the tires are pulled in a lot from lifting it, so it will be going in for alignment on Friday.
This brought a question to mind. When they straighten the tires back out, I assume that the front will lose a little bit of height because the tires will be sitting flat again instead of more on one side.
Does anyone know how much you usually lose in height after a level and alignment? Kind of wondering if I should push it up a little past level so that it will be correct after alignment?
StayStoney
