SilverSport
- Joined
- Nov 8, 2022
- Posts
- 140
- Reaction score
- 274
Which is why I bought an extra alloy wheel and have a full size spare.265/70R17: 31.61" tall.
245/75R16: 30.47" tall.
Well done, GM.
Almost exactly what every police dept does with their tire pressures.... I have tire pressure set at 36 PSI as I found 30 PSI far too soft with OEM wheels and near OEM tire size ...
How does one know what their payload is? If towing heavy, isn't the "fail-save" to inflate to max pressure rather than be under inflated and experience a catastrophic tire failure?There's a good bit amount of bad information in this thread. You should basically never use the max sidewall pressure unless you are also at max payload. If you can't feel the difference between 51psi and 35psi -- I'm jealous of your smooth roads. 10-20% over recommended will help in steering feel, but if you're driving these boats I'm not sure if that's worth pursuing.
If you're using a non-oem sized tire, you can use this to figure out what pressures to run as a starting point: https://tiresize.com/pressure-calculator/
