drakon543
- Joined
- Feb 15, 2016
- Posts
- 2,473
- Reaction score
- 1,714
So when i first bought my 97 last year it needed an immediate tune up and distributor. Judging by what i was seeing when i was going over the truck i wasnt sure what else i might find so i decided to buy cheap replacement parts. I had tossed a cardone reman distributor whatever cheap plug wires and autolite plugs just to get the truck running again. Well ff to now pay for what you get truck was missing like a MF so i ordered ngk gpower plugs, summit racing performance coil, taylor 8mm spiro wires, and an msd street fire distributor. Ive had great luck with all those brand parts so i decided to go with it. Distributor is an exact replacement for a gm oem dist however vs my cheap reman one the oil pump shaft had to be bumped back a touch to drop in where it needed to be. Also ive used the msd blaster coil before and it comes with the extra hardware to attach it to the coil mount bracket the summit racing one did not. So if you decide on the summit racing coil get some small bolts and nuts to reattach it as the oem has aluminum rivets that hold it together. Its only been 2 days worth of driving but it feels great and very smooth vs the junk parts i had originally used.
Taylor plug wires= tay-74236
Msd dizzy= msd-5592
Summit ign coil= sum-850503
Ngk plugs= ngk-3403
Summit racing part numbers if anyone is interested.
Msd dizzy= msd-5592
Ngk plugs= ngk-3403
