Oil consumption between changes
Scott in AZ
Arizona
I drive my 2001 Yukon 4WD regularly , about 4,000 miles per year. Currently 172,000 miles. Im rough on the suspension heading to the trail head with my mountain bike, but I’m on eggshells on the gas pedal. But it’s worth it. I consume much less than a half a quart between annual oil changes. Just checked since last change in December 2022 and it seems like it is still completely full. I use my mechanic’s bulk 5W-30; or on my own I use semi-synthetic or synthetic 5W-30. Whatever seems like a current value, but stick to good brand.
B-train
As I understand it, the 6.2 engine from the K2XX generation, and the 6.2 engine from the T1 generation, have in common only in the working volume. These are slightly different engines, with different modes of operation. The same AFM on K2XX and DFM on T1 work differently. On K2XX, I drove about 150 thousand km on 0-W20 oil, and the consumption was always the same. This is about 1 liter per 12 thousand km. Therefore, I have a feeling that switching to X-W30 oil will not give a change in oil consumption
The new HD pickups with the 6.6L don't have any active fuel management system, but they share the same engine architecture as the LT 6.2L from what I understand. All V8 all the time......the way it should be in my book.
The previous LS 6.2 and LT 6.2 are different animals in many ways. The LS is 6 qts, the LT is 8 qts capacity. I'm sure some of the block stuff may be similar, but many changes were made as you implied for DFM and AFM, as well as direct injection.
B-train
I believe that it, as most posts here reiterate, that skimping on oil changes does nothing but create potential issues down the road. Whether it be lifters, oil pump issues, timing chains, etc. Oil and filters are CHEAP longevity enhancing items.
Interesting case: my sister has a newer Palisade. She has always done what Hyundai says is the recommended intervals. They use a synthetic blend and say it's good for 7500 miles. Fast forward to 70K and now it burns a quart every 1200 to 1800 miles. YUK!
We advised changing it more frequently and see what happens. I hope it turns around for her. What a joke.
Marky Dissod
1. Hyundai, like every other vehicle manufacturer, wants each vehicle to last 10 years / 150000 miles
MAXIMUM.
Why would they or any other manufacturer recommend oil change intervals that would allow the vehicle to last long enough to eat into their future profits?
2. An ounce of maintenance is worth a pound of cure.
If a Hyundai Palisade takes 6qt per oil change, & she should have changed it 2x as often ...
By the time the engine has cumulatively consumed 60qt of oil, she'll be rid of it /in the market for a newer vehicle anyway, which is exactly what Hyundai wanted - and what every other manufacturer also wants.
TL, DR:
Change your oil somewhere between 20% & 50% more often than recommended by the vehicle maker / oil / filter.
TexasLC
My 2021 is starting it's 2nd oil consumption test after the first one was done incorrectly.
Right now, I'm appearing to be burning about 1/2 quart every 1,000 miles. But again, my test was done wrong so we're starting over.
Dealer gave me literature from GM that says 1 quart every 2,000 miles for normal driving is acceptable...that seems unacceptable to me...
My last full oil change, I went 5,000 miles roughly, checked the dipstick and there was just a tiny drop on the end the dipstick.
Can't believe these motors are burning this much oil. Or am I just being overly picky?
The car has only 44,000 miles...
dbphillips
What engine?
mp5pdw
I think it is luck of the draw if you're getting a well built motor or one destined to go through oil like crazy. I own a 2010 Cadillac Escalade EXT with the 6.2 liter and it doesn't burn oil. I am not gentle on it either it has 165000 miles on it recently replaced the transmission but it runs great. I run Costco synthetic oil in it and change it every 3500 miles. I spoke to my local Chevy service advisor recently who said going through a quart of oil every 1000 miles is expected in all GM products, I was surprised to say the least my only guess is they're wanting the owners to hold off oil changes until they reach 8,000 miles so the oil will run like molasses through them instead of motor oil but that would be great for business for them
Marky Dissod
I think it is luck of the draw; if you're getting a well built motor, or one destined to go through oil like crazy.
Luck is the residue of design. Example:
How many more stolen vehicles would be the result of everyone leaving their doors open with keys in the ignition?
More germane example:
Betcha the L8T will have a nearly flawless reliability record, not only due to lacking 'Doze-off' and Cylinder Confusion, but having a forged crank and rods.
I am not gentle on it either it has 165000 miles on it - recently replaced the transmission, but it runs great.
1. Every 3500 miles? IMPRESSIVE.
2. Although both are 6.2L, your L94 is NOT an L87.
I'll go so far as to say, most L92 / L9H / L94 failures are the fault of the previous owner(s), who
didn't change oil often enough
drove like leadfooted idjits while using 87
whereas most L87 failures are GM's fault for showing Boeing how to pinch pennies until they bleed.
JKeller
I'm late to this thread, but both of my most recent Tahoes (a 2015 5.3 and now a 2021 6.2) stopped burning oil when I switched from 0w-20 to a heavier 0w-30 Amsoil.
Vladimir2306
The 6.2 generation 21+ engines have a problem with the rotation of the crankshaft and the destruction of the liners. Our mechanics believe that thicker oil, in particular 5w30.or 0w30, is to blame. Because the oil does not get where the manufacturer intends
coffeeguy
