Pickup tube question on 2007 GMC Yukon Denali 6.2
Los Angeles, CA
I'm there with you. I had low oil pressure right after doing an oil pan gasket and o ring swap. but my truck has DOD. my cam bearings and rod bearings were shot so that also game me low oil pressure. hope you don't have my luck!
C
Charles Hughes
Well if you look at that cam picture it's pretty worn. So maybe I will order a stage 3 kit, new chromoly push rods and see where that takes me
Geotrash
Dave
Richmond, VA
Here is a question for everyone. I looked at the cam right before reassembly and I'm noticing some marks. Wondering if I should replace this cam? Should I consider like a stage 2/3 kit?
Yeah that cam is damaged. Time to yank it out of there. Careful with a stage 3 though. I had a BTR stage 2 cam with a lope for a while and hated it; it would surge annoyingly at traffic lights. A higher stall TC would've helped but I just didn't care for the lope in daily driving.
To replace it, I went with a cam motion stage 2 truck cam, specifically because it has a smooth idle. You can tell it's cammed and it makes great power, but it's smooth.
Foggy
KS
Any "Stage 3" cam belongs in a lighter weight car.. Not a truck..
And unless you are going with a 2800 stall, it won't work at all..
I'm sure someone has made it work, just not a true daily commuter suv
Also, if the cam bearing surface is damaged like you show
it's very likely that your cam bearings are worn...
So even a new camshaft will do nothing for your oil pressure issue
Geotrash
Dave
Richmond, VA
I think those are just the lobes, but I agree that it’s worth checking the cam bearings.
sylentnite
