Piggybacking the Bose Amp / Upgrade Advice
choodock
choodock
Waco, Texas
I finally had a chance to wire up my Pioneer HU yesterday. I wired the radio in without an interface and used a relay and tapping into the RAP wire for the power sunroof (which my Tahoe doesn't have) to allow the HU to function just like a factory stereo. I don't miss the chimes at all! I also used a relay to turn on the Bose amp when the radio is on. Another relay is for the reverse camera that is also hooked to a heavy duty diode that allows me to view the camera at any time. I used a switch on the remote wire from the HU to the relay to turn on the camera whenever I want, but it always comes on in reverse. It's an unnecessary feature, but one that I had to have. I only tested the backup camera as I have not installed it yet because the seats all have to come out in a few weeks to switch the old tan carpet out for black rubber flooring. I'll run the wires for the camera and the amp and subs when the carpet is out. I also added a 4 gang fuse block under the dash. I used Rockford Fosgate female RCA lineouts soldered to the bose amp speaker inputs. Everything works flawlessly thus far. The Pioneer AVH-X5500BHS sounds better than my NNBS Silverado with Bose. The Bose sub helps add balance to the system because the Pioneer 6.5's offer virtually no bass. I also got the sub box sitting under the second row seats, although now I can't lay my seats flat. I'm thinking of going with some Rockford Fosgate R2SD2-10 subs instead of the Pioneers. I have not decided on an amp yet either because I am looking for a place to mount the amp.
choodock
choodock
Waco, Texas
I also spent some extra time mounting an aux input and usb input in the console. I mounted the relays under the steering column. The bracket holding the BullyDog only has one mounting screw until I find its final location.
choodock
choodock
Waco, Texas
Does anyone have any thoughts or recommendations on 10 inch shallow mount subs? And an amp to match? I'm not trying to build a system you can hear and feel from a block away; I just want some bump in the backseat. I'd like to spend around $300 for the subs and amp.
My Tahoe sounded terrible with just the base stereo and some blown speakers, so where I am now is worlds apart. In the future I'd like to upgrade to some nice components in the doors and power them with a 4 channel amp.
Ftrsavage
Pittsburgh Pa
How did you wire ur head unit without a interface.... I have the lux bose system in my 2001 yukon Denali and I installed a new head unit but I don't get any sound....
This thread was last updated in 2013 and that member hasn't been on here since 2014 so don't hold your breath. PAC makes harnesses/ steering wheel control interfaces that work well. Sounds like your amp isn't turning on.
Dev00
