Radio and Turn Signal Audio Anomoly
UsualSuspect
SoCal
Last night I am driving, go to make a left hand turn, used the turn signal, heard it through the drivers side speaker. About 10 seconds later the audio for everything, including the turn signal muted for about 5-6 seconds, then unmuted and worked fine. Around 30 minutes later, staring at a red light and traffic, the right turn signal was on, the radio was playing, then it all muted. this time I looked around and everything appeared normal and working, but it obviously wasn't, no sound for about 20 seconds, then the turn signal and radio audio came back on. I had my mechanic take a look this morning, no codes set, everything passes diagnostics.
StephenPT
St. Helens, OR
There's radio software update available that is supposed to address audio cutting in and out. Y171 is the software version - here's the TSB. https://static.nhtsa.gov/odi/tsbs/2023/MC-10246261-0001.pdf
GM seems to have paused OTA updates, at least on the SUVs. I haven't seen an update come through via OTA since last August. I wish they would push this version via OTA, but for now it seems to be a dealer only update.
Micahsd
Just curious…do you know if that update exists for the 2021 model year Tahoe?
Mine’s been doing that for awhile and they’ve applied a few updates to my system.
StephenPT
St. Helens, OR
Sorry, I don't. I just keep track of the TSBs that impact my '22 with the Google based infotainment. '21 is, as you know, a totally different radio interface.
You can browse through the TSBs on the NHTSA.gov website and maybe you'll find one similar that applies to yours? https://www.nhtsa.gov/vehicle/2021/CHEVROLET/TAHOE/SUV/4WD#manufacturerCommunications
tspjim
