vcode
- Joined
- Feb 15, 2015
- Posts
- 357
- Reaction score
- 224
Just curious, can you take a measurement from the frame to the seam weld (or something easy to measure) under the rockers to see if that is the same side to side?
Raise it up some and get smaller wheels and tires.For like…the 5th time: the RF tire scrubs the fender, the LF does not.
This is the 4th set of wheels that's been on the truck. 3 OEM sets, 1 aftermarket.I would just put it on an alignment rack and take measurements
1/4" is really not that bad as long as tire wear etc is good.
It could just be that your aftermarket wheels are a bit off or the
difference in tire sizes from OE are giving you the "scrub" concerning you
Or that when brakes or wheel bearings were done in the past that
the hubs/wheels/ etc were not all cleaned the way they are supposed to be
I'll be on an alignment rack Tuesday, so I'll measure everything then!Just curious, can you take a measurement from the frame to the seam weld (or something easy to measure) under the rockers to see if that is the same side to side?
