Right front wheel protrudes further than left?
vcode
Just curious, can you take a measurement from the frame to the seam weld (or something easy to measure) under the rockers to see if that is the same side to side?
Foggy
KS
I would just put it on an alignment rack and take measurements
1/4" is really not that bad as long as tire wear etc is good.
It could just be that your aftermarket wheels are a bit off or the
difference in tire sizes from OE are giving you the "scrub" concerning you
Or that when brakes or wheel bearings were done in the past that
the hubs/wheels/ etc were not all cleaned the way they are supposed to be
KidWgn
KidWgn
Certified Kid Hauler
St. Louis, MO
This is the 4th set of wheels that's been on the truck. 3 OEM sets, 1 aftermarket.
KidWgn
KidWgn
St. Louis, MO
I'll be on an alignment rack Tuesday, so I'll measure everything then!
Big1975
