Shock Extenders for factory shocks?
E-Force
I have a 2005 Denali lifted in front by 1-2 inches. I've decided to replace front shocks with factory electronic dampening type. I'd like to maintain full travel of the shocks, so can I put on metal shock extenders? I'm concerned that the electronic signal might not go through the metal shock extenders. hmmm.....
Trey Hardy
Eastern North Carolina
You should be able to you can get a set for about 30$ you can try and see if they work
B-train
It's a metal to metal contact. I'm sure they would operate as intended. My only thing would be the ride level sensors maybe getting confused?
E
E-Force
@B-train: Agree, ride sensors probably will be confused. My mechanic did the one-inch level up front. Since then i have not heard the air pump run. I asked him if he disabled it, but he can't remember. The one-inch lift up front is going to have a cascade effect I'm afraid. step at a time I suppose.
JVega
