SOLD 2009 GMC Yukon 5.3 4WD 139K SOLD
FasterBass
Hi All,
Regrettably selling my '09 Yukon SLT, 5.3 LMG, Selectable 4WD, 6L80E, Bench with 3rd row, Bose, 139,6XX miles. Purchased in March 2022 with 134k We ended up getting an X5 through my company car program so this has to go. Looking for $12k OBO. I have since put in over $8,800 in parts and labor to make this truck ready for the next 100k miles. I have an excel spreadsheet that tracks cost for all and can send to anyone if needed. I have shop receipts for the cam install and trans filter/flush. I can procure receipts for all the parts purchased, all installed by me. There are also records for this truck from the PO going back to 2013 (all dealer service).
The truck drives, accelerates, stops like new. Paint is not perfect - lots of scratches around door handles. Looks like a very slight tweak in the front pass fender. PO told me he had a low speed parking lot hit and there is evidence that there was a small fix made. Unnoticable unless you know what you are looking for. Hood clear coat is in-tact but roof is starting to fail. No body rust whatsoever. Surface rust on frame in some spots but nothing unexpected. Just clay bar'd and hand waxed the whole truck and it is looking great! Comes with another set of 18in factory wheels, two will need replacement tires. Also some yet uninstalled parts.
Truck is available to be seen/driven in Goshen, NY during the week after 7pm, and most weekends. Please call or text 845-558-0126 if interested.
Major services performed since purchase at 134k:
FULL DOD delete kit from Brian Tooley racing:
-BTR Stage 2 Cam
-Remanufactured 799 heads
-Beehive springs
-LS7 Lifters
-New lifter trays
-New Melling high volume oil pump
-HD timing chain
-ARP Exhaust bolts
-Professional shop installation with receipt for work.
Black Bear Trans and Engine Tune
Full transmission flush and filter @134k
Updated Valve cover
Catch can
AirRaid MIT with filter
Plugs/wires
New Fuel pump assembly/replacement lockring (dropped tank, did not cut floor)
KYB MonoMax Pre-assembled struts/MonoMax rear shocks
Belltech 2in rear lowering springs (levelled out with stock front height)
Airlift 1000 helper bags
F/R swaybar links
MOOG front diff mounts
Replacement front CV Axle
New HD Driveshaft
MOOG front replacement hubs/sensors
Powerstop Z36 F/R brake kit (rotors and hi performance pads)
Full brake flush
Updated 20in wheels from K2XX chassis
Interior cabin filter upgrade
Durofoam replacement seat foam
Polished headlight lenses and installed LED upgrade bulbs
LED fog lights
Black GMC front and rear emblems
Front and Rear Carquest replacement calipers PXL_20230819_125429844.jpgPXL_20230819_125456960.jpgPXL_20230819_125600002.jpgPXL_20230819_125617864.jpg
DB1337
