Tranny upgrades
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
gonna start pricing a tranny rebuild but might as well upgrade with stronger components. You guys have recommendations?
"The Beast" sun shell, 5-pinion planetaries, upgraded servos, whatever clutch pack is the flavor of the month...
You doing it yourself?
Good luck!
It's one of those "while I'm here I may as well..." snowballs. Sure, there are the few parts that are known weak points even at stock power levels such as the sun shell. But, while you have it open and parts removed, are you really going to be able to control yourself and upgrade JUST those parts?
Beyond the wear items, there's billet hard parts such as shafts. Replace the plastic accumulator pistons with metal ones...
Performance boost valves...
A performance valve body wouldn't be a bad idea if you wanna make changes there. You don't wanna just raise the line pressure through the tune to alter those characteristics.
I'm no auto trans technician, I just studied up a little on the 4L60E before deciding to buy a built one instead of building my own. I still have a damned unused FLT Level 6 sitting in storage. I never sold it with the rest of my canceled project parts because I might need it for the Tahoe. But now I'm trying to see what would be needed to swap in a 6L80 with all factory functions (tap shift on column, correct gauge/display cluster, etc.)
sumo
sumo
rhode island
Maybe if there is one already built with upgrades parts I could just swap in and send in my core
There are plenty of options for that: Finish Line (my pick), Performabuilt, Phoenix Trans...
You get what you pay for.
Big Buttons
The SS Burb
South Texas
Hands down go with Robert from transbuilderguy or jakes performance.... only guys that will build a trans for me... I have Roberts lvl 3 80e.
How much does something like that go for? I'm trying to make plans for mine when it goes. Which it will!
Leno1364
