What's Wrong With Your Yukon/Tahoe Today? ...And How Long Has This Been Happening?
ProfeZZor X
High Country
I noticed that every random thread here seems to include a main topic on something which is eventually followed by a series of posts a few pages later that occasionally talks about someone's ride having a problem. Not major issues, but little ones that don't require time in the shop. I thought it would be interesting to create a universal thread on the quirks and issues you experience in your daily driven Yukon/Tahoe, to share them with everyone here in hopes of finding a solution that others may have. If it's a common problem that others can relate to, maybe it can be discussed and resolved here.
I'll go first...
In the 2 months I've owned my Yukon AT4, I occasionally hear a "thud" behind the driver's seat, as if a bowling ball hit somewhere behind me when I'm driving alone. Nothing moves around back there, it only happens once a day, and I don't feel any vibration in the floor when it does happen. I thought it might be the sliding rear seat, but it takes some muscle to slide them back and forth because of how stiff they are on the sliding track. And my kids never adjust the seats either. Very strange.
*Admin: If a similar thread already exists, please delete this one.
todayusay
the 2021 AT4 we sold last week had developed a reverb "in the speakers" when talking on the phone and using bluetooth through the vehicle. it was so bad it was unusable. Had a dealer diagnose it back in November and the first time they looked they admitted later that they didn't do anything to remedy the issue as they "didn't understand our concerns"...aka didn't believe us.
we took it by a week later and let all the advisors and a couple service guys listen to it and their initial reaction was that it may be a "cable" that would require removing the dash...at this point we had enough of the Yukon...was hoping buying a first year design wouldn't have had any issues - boy were we wrong
other issues off the cuff
- Service rear axle warning - think rear end control module fixed this
- Sunroof trapping water - actually a TSB on this (if only the dealer knew about the TSB)
- idler pulley had to be replaced
- SD card removed message kept coming up randomly - two dealers tried to diagnose this to include replacing the reader
- Several software updates
- auto step motor went out...trust me you'll know something is wrong if this happens
david1523
SoCal
New 22 Denali owner and my AM/FM radio doesn't work for some reason. Ive had it about 2 months and just noticed. We have Sirius and use Spotify 100% of the time which is why we haven't noticed, but it's still strange. When you hit the media button the options for both are "greyed out" if that makes sense, like it's not an option to choose, and when we do all we get is static.
PaulGA
Only issue so far, and its a super small annoyance.
Randomly happened twice: Music volume (either XM or Bluetooth) won't change with the volume knob. It changes navigation volume (I dont have navigation destination set), I had to set a destination, wait for the directions to talk, and quickly turn the volume down while it was talking to adjust music volume. Turning off/on the car fixes it, but while driving that wasn't easy.
ProfeZZor X
ProfeZZor X
High Country
To be honest, I haven't touched my AM/FM radio since I got my Yukon. I've been using the blutooth and satellite radio 100% of the time. What annoys me is when I switch from blutooth to listen to the satellite radio, then turn off the vehicle and exit. When I return and start the vehicle, it reverts to the blutooth instead of satellite. And that "tab" is too tiny to switch between modes... unless there's a shortcut on the steering wheel I hadn't figured out yet.
a lot of these radio issue's can probably be cleared up by simply disconnecting the battery for a minute and reconnecting it.
any feedback noise from using a cell phone or playing certain media is probably the ANC (active noise cancellation), this can probably be resolved by disconnecting one or more of the ANC mic's and there is probably no other solution for that.
franklin455
I'll go first...
Hey I had this exact same thing on my 21 Denali. Go push/pull the back of the second row seat back and forth to see if that is making the noise. The connection between and seat frame and the floor had some slop in it on mine. I took mine to the dealer and they replaced the frame on that seat....solved the issue. However, make sure that they put the seat cover back on correctly. When I got home and tried to put the carseat in there were no anchors present as they had covered them up with the leather, resulting in a return trip to the dealer.
ChemEng
22 Tahoe Z71 -- my headlight sensor was bad from the factory (headlights would come on in bright sun). Even though there was a trouble code for the sensor they still didn't believe that there was a problem... took almost 2 days, and an escalation to the service manager to convince them that this 100% repeatable problem was actually a problem. Thread on this problem here: https://www.tahoeyukonforum.com/threads/question-about-the-headlights.133415/post-1675350
Also, my Z71 badges on the front quarter panels are coming off. The double sided tape isn't sticking. Dealer ordered new badges, hopefully they will let me install them myself, because i don't trust them to get it right, or maybe i'll just delete them and keep the new ones in the glove box for when i sell it.
slade45
"Service Safety Restraint System" alert keeps coming on, despite having taken it in to get repaired (I think this was under a recall)...
todayusay
forgot one of the more recent ones
passenger right side - when going 60 or faster there would randomly be a noise that sounded like the old school radio antennas rattling when they were loose...soft knocking noise.
online searching revealed that it was probably originating from a heat shield that was loose...several others having the same issue...we had already given up on fixing anything else by this point
SRobinson541
