93blkongreenpro
Finished removing the molding and cleanup yesterday.
Looks good! Yall make me want to do mine. I want the 15 body moulding.
Got something in the mail today to hopefully be able to get the radio installed.
Clearly, I didnt read that I needed it when I purchased the Maestro Rr.
Edit:
The stuff.
I have to resolder the factory radio harness since the P.O. cut them off. The rest should be a snap. The Vehicle diagnostics plugs into the obd port, but I may solder the wires and hard wire it since I have my bully dog in there.
Now to print out the diagram for what goes where and what is not needed and get the Rr programed for thr truck and figure out my steering wheel secondary fuctions that I want to have.
Sent from my SM-N910P using Tapatalk
CHOO CHOO
BackPagePhil
Manheim, Pa
You people are bad. Now i pulled my moulding off too. I held out for soooo long and you shmucks finally made me cave.
Got drivers side done, will finish the passengers side tomorrow
vinnyray
Lancaster, PA
I held off for months but the damn molding was holding water and causing deposit buildup running down my door to the point where it started to rust
BruceWayne
