Two Modifications for Yukon/Tahoe If Your Ride is Rough and no HIDs
Cmicasa the Great XvX
and OH.. they BEAM. Seriously amazing that these are not simply the go to instead of doing an HID kit. BRIGHT and literally as easy as putting a normal bulb in the vehicle. To any dude reading this and thinking that he can't do it.. MY 12 YEAR OLD DAUGHTER did the DRIVER SIDE while I did the Passengero_O
Yes I have the 80watt
Bo3131
Woodbridge, Va
If you get time a picture of the output would be nice. Being 6000k do they have that strong blue look or do they match pretty well with the stock LED headlight strip.
WingsAA
CMFIC
Dallas, TX
I'm curious if these will fit into the high beam location. I think the is less room in the housing for high beams.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Broham
So Cal
Thanks guys... Not sure why I couldn't find them during my search
Sent from my SM-G925T using Tapatalk
ajs800
Michigan
I see you have the driver placed within the housing...doesn't this create a lot of heat? Also, any pics of lights operating? This might be the ticket but to date every aftermarket led replacement I've seen hasn't quite cut it compared to HID. Thanks for sharing.
AngelXL
I did both high and low headlights same size same everything.
Check out my thread for pics.
LEDs package
NipRing
