Tire Size
kwOH
Banned
Ive read a lot of threads about max tire size on stock 17s, some say 285/70 will fit, others say you have to crank the keys, so will they fit, or not with out some adjustments and if they don't fit then what does fit? Thanks in advance for input.
BigDaddy13440
Rome, NY
285/70/17 will fit, but you MAY have to crank the keys up, but hardly doubt you'll have to max them out.
Some have said that 295/70's will fit, but you'll most likely need to max out your stock keys. Or, you could add leveling keys and rear coils/spacers.
dak244
So in the above instance, would it be better to have a 0 offset or -X offset to avoid rubbing without cranking the keys?
UPSdriver
