Calibrate Shift Points, and Engine Rev Limiter.
Justin
I understand. This setting works with the shifter in direct (D), or is to work through the changes (1-2, 2-3; 3-D), and vice versa (D-3, 3-2, 2-1)?
Regards!
Those shift RPM tables take effect in all shift lever positions.
katz_kaw
katz_kaw
Chile, Santiago
Dear,
Right, but when you set up and the shift lever is in "Direct" (D) you will notice the changes?, or should I go by moving the lever by each number change (D-3, 3-2, 2-1) and vice versa, and just note the made settings?.
Excuse me so much question, do not understand much, and so I want to be well informed.
Thanks. Regards!
witty_name
