Question for upgrading Towing capacity 06 Denali
techswabbie
We have a 06 Denali with roughly 190k miles on it. My understanding is that this model has a towing capacity of approximately 8100 lbs. We have a travel trailer that we just purchased that has a GVWR about 7600 lbs. We rented a 3500 Dodge Ram to tow the trailer for 10 days because I didn't feel our Denali would be able to handle the haul (about 1500 miles in mountains).
Rather than go out and buy a "new" truck on a loan, I wanted to see if there was anything in addition to an engine rebuild that we could do to beef up the suspension and towing capabilities. The Denali currently has the Air Ride suspension (replaced in 2017). In addition, I've been told by a few local shop guys that we're going to run into ongoing problems with the alignment and uneven wear on the tires... so any advice for heavy duty (read: proper) towing would be very much appreciated.
T
techswabbie
Short wheel base and 2WD? I figure you have 3.42 or 3.73 gears and would need to go to 4.10. 6.0 LQ9 engine with 4L85 transmission?
@intheburbs
I have the 6.0 and 4WD/AWD currently. My issue is I don't want to be dragging the rear on the ground when towing at or near the limit. I've heard that a lot of the 1500 trucks are just beefed up with "air bag" kits and that that is the biggest difference between them and the 2500 series chassis/design.
No, the 2500s are very different underneath and much much stronger. With a trailer that heavy, I don't think you're going to be at or near the limit but rather quite a few pounds over it. You could add the air bags in the springs or timbrens, the former can support an additional 1000 pounds. The timbrens can be had for up to 2000 pounds I think, it's been a long long time since having anything to do with those. Check them out too.
The AWD drive kinda rules out gears and such. Bill will have better advice than I, wait till he shows up before doing anything.
intheburbs
SE MI
The whole 1500/2500 difference thing is deceptive because the trucks share the same body. Underneath the body, they are COMPLETELY different trucks - frame, suspension, powertrain, axles, brakes, etc.
Is your Denali a Yukon, or a Yukon XL? The difference in wheelbase/length will make a big difference in the stability/comfort of your rig.
How long is your trailer?
The trailer's GVWR is meaningless. What does it weigh? Have you put it on a scale when fully loaded for a trip?
The biggest issue/concern you'll have is the rear axle. It's the weakest part of the powertrain, and it's the first rating you'll probably exceed. I'd be willing to wager you'll overload the rear axle long before you get anywhere near 8100 lbs of trailer. Suspension ugrades are fine, but they don't change how much weight the axle can handle. If you're willing to spend some money, find out what you can do to beef up that axle.
I towed some large trailers with my '01 Burb, and I blew up two axles in the process. It's now wearing rear axle number four. Part of what made it easy to overload the rear axle was the fact that I had the ZW7 "premium smooth ride" suspension, which included the self-leveling shocks, so no matter what trailer I attached, it never sagged/squatted.
Never had any issues with the engine and transmission. My friend now owns the truck, it's up to 245k miles with the original engine and transmission.
This is the critical information you need. Get your rig weighed, and compare it with your limits. If you haven't done this, everything else is speculation and conjecture.
6speedblazer
on a denali the rear air ride should keep you fairly level. My 05 denali XL tows like a dream
so the two areas i would be concerned with are the transmission and rear axle.
the 4l60e is a decent trans in the right platform. if you are going to to a lot with a denali, upgrade to a 4l80e. these trucks are heavy and can be pushing the limits of a 60e when a trailer is in tow, especially one as heavy as yours.
the next area of concern would be the 8.5/8.6 10 bolt. again not a bad axle in the proper application. but if you are going to be towing a lot you would be better off in the long run with a larger axle. I have had good luck in the past adding a differential girdle and building them with main cap studs and solid pinion spacers, but by the time you get all that and install it, you could have paid for most of a larger axle.
in the end as much as i hate to say it, it really sounds like you need to step up to a 2500 series vehicle for your towing needs.
intheburbs
SE MI
The 4l60e is a decent trans in the right platform. if you are going to to a lot with a denali, upgrade to a 4l80e. these trucks are heavy and can be pushing the limits of a 60e when a trailer is in tow, especially one as heavy as yours.
The 4L80E is certainly a beefier transmission, but it's also a few inches longer so it's not a simple swap. You'd need to also replace the driveshaft, and you'd need to move one of the crossmembers.
The 2500 trucks get the 10.5" full floater rear axle. American Axle rates it to 10,000 lbs in other applications, compared to the 4000-lb rating of the 10-bolt in the half-ton trucks. The limiting factor on my 2500 rear axle weight rating is the load-carrying capacity of the tires, not the axle.
adventurenali92
Big Bear Lake, ca
His truck should have a 4L65E trans. That’s what was standard in the 2006 Denali. That’s what my 2006 Denali has. I tow with my rebuilt 4L65E and it handles fine. Although I’m not pulling anywhere near that amount of weight and my trips are short around town trips to and from the lake. But at any rate I agree the 4L80 trans is a tank for towing.
T
techswabbie
Wow! I'd like to reply to everyone individually - THANKS! I had some basic understanding of physics as it applied to our Yukon Denali and was very hesitant to try to drive it across state as my wife originally suggested. I knew it would be a disaster. I was also unsure about the whole 1500 vs. 2500 comparison. Seemed fishy to have a few folks locally say there were only minor differences based on the add-ons. Glad I posted here for feedback and advice. For clarification, my trailer is a 2007 Pacific Coachworks Tango 311BHSS. It is 31 feet in body length and 34'10" on the hitch total. Dry weight was supposed to be about 6500 lbs and loaded at 7600 lbs.
My wife REALLY likes our Denali for a daily driver. It has a few flaws - overhead fan buzzing, driver seat head rest busted, multi-disc player doesn't work and the oil sending unit has gone native throwing false engine codes every other day. Otherwise that's all low cost issues. I am concerned about the front suspension as our new(er) tires are showing uneven wear and I'm told that's par for the course on this era of the model. So I'd really like to get it into a shop and have them just blast it with all repairs in one round. The pain is we only have one vehicle as my commuter is a company car. So to get all that fixed, I'd have to rent and put her in a minivan (aghast!) for a few days. Looking at trading it in, but didn't want to sit on a car payment for 4-6 years if we didn't have to. So many decisions! Thanks again!
mals
Western Mass
It looks like you already received some good information, but I wanted to add my experiences since they may be relevant. I purchased my 2005 6.0L AWD Yukon Denali specifically to tow our Gulfstream AmeriLite 21MB. Like yours, mine has a max tow capacity of 8,100lbs, front axle rating of 3,550lbs, and rear axle rating of 4,000lbs. The trailer has a dry weight of 3,330lbs and a max loaded weight of 6,240lbs. As the trailer sits when we are loaded to camp with food, gear, solar panels, A/C units, batteries, propane, etc. it's between 4,500-4,600lbs with a tongue weight of 500-550lbs (~12%). Even though I am 3,500lbs below my tow limit when I went over the CAT scales, I was only 200lbs below my rear axle rating. That is even with the use of a weight distribution hitch and torsion bars to pivot some of the tongue weight to the front axle.
All that to say my setup tows great and I would hop in it and drive across the country if I had the time without hesitation, but if I was going to tow anything bigger or heavier than my 21' camper I would look into a 2500 series platform vehicle.
terryseverson
