Vortec 454/4L80e HD swapped 1999 Tahoe OBS
6.0 Carb Conversion or Stay EFI?
  • Carb Conversion
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
It’s SUPPOSED to be, but it’s not. Maybe if I applied far more cans it may have darkened up, but I used 4 cans of Duplicolor Perfect Match midnight blue metallic.
Not so perfect. Did you try to match a spot that's not in the sun so much? Like inside a door jamb? Being that it's so old and the sun does things to paint color--UV.
bigfootchiro
bigfootchiro
Largo, FL
Does anyone know how true this is? I’m assuming it is. Knowing the 454 runs at 4bar, which set would be best? I was thinking LQ4 6.0 or 5.3 injectors that run at 26 lb/hr at 4 bar, along with the 0411PCM swap (to be tuned with that injector)
randeez
south florida
i would go big....for when you supercharge this thing :anitoof:
Do the most common injectors - I am not really familiar with 0411 tuning but theres a good chance if you use a common ls1/ls6 style injector oem or even a generic 60lb/hr injector someone will have all the data the tune will need
