check the power connections mine was acting up transmission was playing dead.
basically it would not go, i had to keep the rpm at 1,000 just to keep it from stalling out..
check and see if there is any
stressed cables those are the ones that have the bad connections
today I had adjust the power cable (released the stress by giving it some slack by adjusting the battery location slighty) as it's internally damaged.. these NNBS are sensitive to issues with the power cables and the power delivery(as they made changes to the NNBS) but i know for sure mine are damaged.. I messed with them abit you can see the cable suffered major damage...from an accident (that the dealer lied about)
it takes a ton of force to get those crimps apart.
i'll be ordering new cables soon hope the damage is limited to just the break out cable (39$)as the second part of the positive power cable is $250
just for a Proprietary electrical cable
i can afford to buy it but rather use that 250$ for something else like maintenance or new shocks in the rear
