Where can I buy the sunroof motor / actuator?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
This is insane... So, the part is discontinued. However, there's other vehicles that used it. I found one by chance surfing eBay. It's the Mercedes Benz ML320 between 98 and 05. I think it's the same motor, pics look exact same and Siemens part number stamped on motor casing is the same. I ordered one, wish me luck. It looks the exact same, I'll see if it works the same. It's WAAAAAAAAAAY cheaper. Just paid $27 for the motor, granted is used, hopefully gears got some life left in them.
Then I'm going to glue the gears back together in these two motors I have and hold them as spares perhaps or if somebody needs one on here maybe they can have these.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Never seen this gruvenparts.com. I may have to search for the gear set. I seriously think this is a business opportunity rebuilding and or selling motors for these. They are the weak point in the sunroof design, no doubt, and they aren't made anymore. There's a million + of the 2000 to 2006 tahoes / K1500s out there. I'm certain most of them have experienced this failure, if not they will soon as plastic gears like this have a shelf life. They don't last forever.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
oh wow you are awesome, genious of ebay search lol
god was looking after me, i found one by mere clumbsy accident on ebay for $25 and promptly ordered it although it is untested [emoji33]
Sent from my SM-A505U using Tapatalk
BG1988
My sunroof was all busted up and missing parts. It's been RTV'ed shut but I'm determined to fix it now. So I bought an another assembly from the junkyard. I've tore it all down cleaned, greased, and tested the new setup. Turns out the new sunroof setup has a faulty motor just like my old setup. The gears are cracked on them both.
I see the motor assembly is AC Delco Part# 15163056 Unfortunately, that part says it's discontinued though. Certainly GM would have a replacement part or updated motor assembly as I'm guessing this is quite common.
Anybody know where I can get a new motor assembly? Or better yet a replacement gear set? I'm going to try to glue the gears back together. We'll see what happens. My truck is a 2001 Tahoe Z71 5.3L etc etc etc.
good luck searching
https://www.ebay.com/sch/i.html?_from=R40&_nkw=39+TOOTH&_sacat=0&_sop=15
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I will have to dig through these gears out of curiosity and see if I can find the gear set that's in the transmission part of the motor.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
tinkering around trying to rebuild gears with jb weld and wire before my replacement comes in lol
Ranger16
