16' Yukon A/C Problems
Plimbob
Des Moines Iowa
Bill,
Was the replacement condenser AC Delco or did you go with another aftermarket brand?
Thanks,
Tim
BlackYukon
BlackYukon
I'm kind of a Retard
Did you put the PAG oil directly into the condenser or did you vacuum it in?
I just poured it inside the new condenser before installing, it doesn't need much, maybe around 2-3 ounces.
Plimbob
Des Moines Iowa
Bill, thanks for the response. I ended up putting 2 oz the condenser.
If you don't mind, I have tried to look up the torque specs for the tightening of the AC lines to the condenser but be darned if I can find anything specific.
From what I can figure out it is between 19-24 lbs. Did you use a specific torque or hand tighten to snug?
BlackYukon
BlackYukon
With the AC lines I tightened them to the point where I was confident there wouldn't be any leaks between them and the condenser. If I had to convert that into torque specs I would say around 50ft/Ibs.
Jsuthe
