cfmistry
- Joined
- Dec 5, 2018
- Posts
- 249
- Reaction score
- 424
So after doing a 3/4" Belltech drop kit I had the truck aligned. Even with the 2* camber bushings pressed into the UCAs, I can't get any better than -1.5* of camber (on each side). That's not even in the normal range. On top of that the caster is WAY off, like 7*, but I don't care about that too much. Toe aligns correctly (thankfully) so tire wear shouldn't be too bad.
Do you guys a camber of -1.5* is going to cause any major issues? I'm kind of fed up and don't want to throw more money into this project. For a 3/4" drop this is causing me a lot of hell. And all my control arms are new BTW (nothing bent)!
Thanks,
Cyrus
Thanks,
Cyrus
