Sparksalot
Bastrop County, Texas
Swapped some switches today. Now I need enough pigtail to use them. Or additional pins with tails to add.
E00DB9FD-7769-40CE-9BD0-BBFE3C757DC0.jpeg DD9B5262-EC77-4C93-BE70-F526C6CB4815.jpeg 4CB944D3-9865-4C64-B8B0-51AD13A24F0A.jpeg
Drok
Cold place in the north
Well after trying to figure out my brake issue the front hub started making little noise today. Guess that could be the issue. Bought the moog hub and it lasted just over a year :confused:
Whats the better one thatll last more then a year atleast. delco, dorman or timkin?
Sparksalot
I’ve put Timken SP500301 hubs on both of mine.
Same advice as last time, Timken, they were the OE supplier at one time, or still are.
Timken.
Swapped the valve cover this morning. Took about 30-45 minutes. I forgot to take a pic of the inside, but it wasn't too bad imo. Outside was nasty af though. I'll take pics tomorrow and post them up.
Sent from my Pixel 3 using Tapatalk
Good work Phil. Torque on those valve cover bolts is a measly 106 in lb or a bit over 8 ft lbs.
Almo7annad
