Rear bumper lower trim piece?
Fireman591
Michigan
Does anyone know if the lower (unpainted) trim piece on the rear bumper is interchangeable between trim packages. I have a 2021 LT and would like to add the trim piece from a premier or high country to gain the cut outs for dual exhaust. My plan is to remove the stock muffler and replace it with a better sounding aftermarket muffler along with dual exhaust with some custom tips.
JR09country
Nice idea, id be interested as well.
Sent from my ONEPLUS A6013 using Tapatalk
Toasty
Yes, it's a simple swap out. Swear I've seen a post either in this forum or over on gm-trucks
ryabrams
In the exhaust thread under the “performance” board this was listed as the needed part: #84751055
Gary, any chance you can help me out with the thread title and page #? I tried to find the post you were referencing, but couldn't locate within the 21+ Exhaust thread (was there a different one)? Thanks!
d0wnShifT
Charleston
Does anyone know if there are the correct exhaust hangars on the vehicle for a quad exhaust on vehicle with a single exit exhaust? I looked under my z71 on the driver side rear and did not see where the exhaust would mount.
Maindog
Installing GM Part # 84751055 rear bottom fascia for dual exhaust exit.
After removing tow hitch cover, remove the 2 metal retaining clips (underneath) that lock it in place and move to new fascia.
Remove black chrome/chrome trim piece. It’s held by 4 white clips that need to be depressed to release tabs.
1 on each end and these 2 middle tabs.
Anaujiram222
