Rear bumper... trailer hitch cover Mod
Joeltz
So I wanted a Cleaner look for my hitch, and studied and measured to cut a hole in the cover, so hitch goes thru the cover .
well if you look at inside of cover you can see mold lines and right in the middle a circle about 1/2 inch in diameter.
Use a 2 1/2 or 2 5/8 hole saw and drill using the molded circle as Center
The Hole will be exactly over the square hitch opening!!
you have to file the bottom of the cut hole Square to have enough room to slide the cover fingers into the upper mounting plate
Hitch goes thru the cover for a CLEAN look and you can put the pin in before attatching the cover
the hitch itself has a hole for the spare tire drop shaft you
can put a S hook and 6-7 inches of chain with a shackle for trailer safety chains I use a small hitch plate when not needing the Ball
View attachment 274308 View attachment 274310
Joeltz
Joeltz
Sounds good but cannot see the photos.
Joeltz
Joeltz
94B2E184-2335-4904-B9E6-198CC06A4EA6.jpeg 8AB5E223-401E-40A6-8CBA-4C749EF899CA.jpg
Philpug
I am really surprised there is not an aftermarket cover option because that area looks awful without the cover on.
89Suburban
Bull in the china shop
SE PA
It does but it is a good rust gauge though.:oops:
Alsherooqi
