@Rocket Man and @iamdub i just went outside to the garage and i see now what y’all are talking about. It does have a negative camber. I’m assuming since i put new wheels on it, i have to get the alignment done since i went down 2 inches.
As @alpha_omega said, changing wheel sizes doesn't alter the suspension geometry. It's the same as someone wearing platform shoes changing them for regular shoes- nothing changed with them, they just have less under them. Also, the wheel size doesn't matter. Your wheel size is two inches smaller, but you have more tire, so the overall size is about the same. It's obviously a little bit of a smaller overall diameter since the new ones rub less. They're actually the stock size, so the tires on the 24s must've been oversized. Your speedometer would've read slower with the 24s but should now be more accurate.
...All just little points.
But, now I'm wondering where the camber came from if all you did was swap wheels- no additional lowering, etc.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I used a leaf blower inside thecopcar the other day. 5 minutes.
Working smarter-not harder!
Back when my kids were younger I had a three step approach. first was let the dog in to cleanup the edible items. Thus included folding up seats. Grab all the large trash items and then the leaf blower to remove the remaining debris.
But where did you blow it to, the neighbor’s?:happy175:
Just Fishing
Can't fix stupid
Utah
No ****. Or doing stuff while drinking then having to redo the work later because drunk me was not as good as he thought.
I always worry about missing bolts, or forgetting to fully tighten something down. :jester:
drinking + cleaning or polishing usually goes well.
I found that organizing = bad. :emotions33:
I have a really good memory most of the time.
but if I'm putting things away and a 6 pack in, i can forget about finding anything unless i clearly marked everything, or if it's clearly visible.
Drove my self nuts for a bit there looking for my battery charger.
turns out not so sober me put it in the air compressor shed.
Right now i'm trying to figure out where not so sober me put my oil pressure gauge set, kuz i need to check transmission line pressures!
:yaoface2:
granted, i haven't used that thing for like 4 years... so it could be anywhere! lol
I ordered a nicer set, because I'm thinking it's in the storage unit.
The one where i got bit by a blackwidow... :banghead:
George B
¯\_(ツ)_/¯
:yaoface2:
Then there is the stuff sober me can't do.
Drunk me was a better welder than sober me.
OffBrandCornDog
