And if you have the tool, (Lisle makes a small cheap one) it's almost as easy to remove. Just an 1/8th turn of the tool and pull the tube out. No having to remove the spring clip with a pick and hoping it doesn't go flying somewhere never to be found!
This fitting type is called a Jiffy-tite fitting and is used on just about all makes/models of automobiles.
Lisle 22990 Jiffy-Tite 4-Piece Low Profile Disconnect Set https://www.amazon.com/dp/B00HDFDIAO/ref=cm_sw_r_cp_apan_glt_fabc_Z3P3QQM03AM30CJWRV8R?psc=1Screenshot_20220102-105947_Amazon Shopping.jpg
BruceWayne
