RooTBeeRthe1st
What a cool truck!!
Chevy Luv. Can't remember the last time I've seen one of those.
My dad always liked them, so my first car was a baby blue 2wd '78. Drove that 3-4 years til i bought my old cobat ss sc. Then he got a white '80 for my little brother, then found a '79 4wd, sold the white one. I found a '79 4wd...turned out to be a parts truck. Sold it, dad found a 350 swapped '75 to turn into a drag truck(still in progress), sold the bably blue '78. Then I found my '80 4wd...not sure if there will be more in the future lol
That 350 swapped truck has to be a beast.
St. Louis
Doing the rearend oil, cover, and QA1 bar today. I dropped the spare and have the OE bar off, the lower sway bar links disconnected (for ease of access to differential), differential cover off and fluid drained. The fluid looked translucent like honey when it was draining. Did have an OE style gasket. Here's pics of inside cover and differential. Old bolts had red loctite on the threads, New bolts have lock washers but thinking of putting blue loctite on them
Sparksalot
Bastrop County, Texas
My grandpa had a Courier with a manual. I learned to driv on that at age 12. A couple of years later he replaced it with a Luv. Still with manual.
I didn’t drive an auto until I took driver’s Ed at 16.
You sure it was red loctite and not thread sealant? Because red loctite usually doesn’t give up without heat added.
89Suburban
Bull in the china shop
SE PA
Good stuff!! Did you drive up on the ramps? I didn't think they would clear under the running boards but I never tried that way myself.
Malik112099
Swapped out the headlights and fog lights today. Think it woke up my sleepy truck a bit.
St. Louis
Yup. Don't forget my front is lifted 2"
Before the lift i could only drive up forward on all 4 ramps.
I decided backwards today so I didn't have to deal with the ramps taking up space behind the rear tires where I was going to be rolling around on a creeper.
Tinkerer4
