3 minor issues I'm hoping you can help with.
Super Moderator
Elev 5,280
You'll be sorry if you use the Dorman tees. @Doubeleive posted the correct part numbers in this post:
partcheck
partcheck
So you have the filter in the OPS opening and it a 2005? Did the filter come with the new switch? did the vehicle already have a filter?
I vaguely remember there being a filter there. I have a new sensor so I'll try replacing it this weekend and will remove a filter if there is one.
I'm getting errors on Amazon that those part #s so not fit a 2005 Tahoe. That thread is for a 2014 Yukon.
Donal
Americus Georgia
ok your thread is 2000-2006 forum. I probably reading this wrong. I will be the bck row, sittin down now.
Purchase your Tees from your local dealer, or got to GMPartsDirect.com and purchase them for a lower price.
As stated above, do NOT purchase Dorman Tees, unless you are in an emergency situation.
Also, wear gloves when you replace the Tees, as the firewall insulation is real aggressive, and your hands will be itching for days.
Sam Harris
The oil pressure sensor issue is likely to be several bad sensors. I went through 4 (all but one were genuine AC Delco), before finally getting one that worked for any length of time (knock on wood..!) and there should not be any screen in there for a GMT800 rig. That started in ‘07.
Dzwisle
