iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 1,003
- Reaction score
- 519
Can you use this all the time?Or tow/haul mode should disable it.
Tow/Haul does not keep you out of V4@iboughtatahoe23 You should be able to use M5 or tow haul mode for the time being until you can properly address the situation
I had it in “m5” and it didn’t go into v4 at all and it didn’t make that grinding noise the whole ride…seems to be working for meTow/Haul does not keep you out of V4
Works for me M5 mode it is then lol
Nooo not the button, shifting into manual gear 5 is what I meant hahaTow/Haul does not keep you out of V4
Manual mode enables you to determine the shift timing vs having the computer do it.Can anyone explain how the manual gears work exactly? And how fast I can go using manual up to gear 5? @NickTransmissions ?
